Can we connect external SSD to RS150B USB C port?
@ROSELOA
Can we connect external SSD to RS150B USB C port to play media files?
The USB C port is development port for software diagnostics.
Other usage may cause side effects or not work properly.
Hi @ROSELOA
I’m ok with the side effects. I just want to check if we can plug in external SSD storage and use for playing media files on RS150B.
It won’t work, it’s for debugging and after service. Please do not try it.
