Cant login to rosetube
I have deleted the Rose tube twice as well as disconnect the power but still the same.
Rose tube version is now 5 9 10 61
I can RoseRadio, Rose FM, music HD file
Please help.
@Eric_1428
As of approximately 2026/Jan/27 (Tues) 2:00 PM (GMT +9) today, RoseTube playback issues have occurred due to changes in YouTube’s playback policy.
We are currently reviewing and investigating the situation.
We sincerely apologize for any inconvenience this may cause.
We are giving the highest priority to restoring the service and kindly ask for your understanding.
We will provide further updates through an additional notice once the service has been fully restored.
Dear Han,
Still having the same problem playing the Rosetube. Please let me know once fixed as I’m tired to check time to time.
Best regards,
Eric
Still suffering the problem for not playing Rosetube video. :frowning:
Resetting the unit/unistalling/installing the Rose tube but still the same.
@Eric_1428
Sorry, we haven’t restored the previously deployed Rosetube on your device. We’ve done that, so restarting your device should restore normal Rosetube playback.
Dear Han,
I just back home half an hour ago. Restarted again, it failed. So uninstalled Rosetube and re-installed. my iphone still connected and it can show selected Rosetube video but failed to play…loading all the time.
Roseradio has no problem
Can you please double check what is going on ?
RoseOS4.17
Rosetube 5.9.07.62
Again disappointed once again.
With my best regards,
Eric
@Eric_1428
Could you please confirm if the versions listed below are correct? > Everything seems to be normal on our end, so I would like to check if you are experiencing this issue with all content. Also, could you please try connecting to a smartphone hotspot to see if the problem persists?
  • RS201 OS: 5.9.09
  • RoseTube: 5.9.07.62
  • RS201 OS: 5.9.09
    yes correct.
    it works by connected with my ipohne hotspot.
so what should I do now ?
thanks,
Eric
@Eric_1428
Are you saying that it might work or not depending on the network connection? Please double-check this for me when you have a moment."
I have connected the RS201E by using the ipone net work and it can play Rosetube video then I switch the network to my home HiFi then it works now .I tuned On -Off several times and it works fine but one thing very strange,not all the video it can play, for example, Woongsan’s songs, a lot of them just can’t load/play.
It is not 100% perfect but at least I can play a lot of Video music on Rosetube. Thanks Eric
@Eric_1428
I’m glad to hear that the issue has been resolved for now. If you have any other problems or questions in the future, please feel free to let us know.
