@ ROSELOA I am using the USB Audio out into Denafrips Iris => I2S into Denafrips Pontus II => COAX into receiver. I am unable to play files from Tidal at 24bits or files from RoseTube mp4. I am able to play Only the 16bit files. If I am to bypass the DDC Denafrips Iris and just go directly from the Rose RS250 to the Pontus everything plays accordingly.
Now, I want to, preferably, be able to use the USB audio out from the RS250 into the DDC Iris then I2S into Pontus II. Is there any setting that I need to change in order to be able to play all files format 16, 24bits, MP4, etc Via USB Audio out??
Thank You!
