I’ve noticed an issue where if I attempt to press previous track in a song list,
…Rose reports the following about ‘expired permissions’:
…yet, my device is successfully registered and otherwise performing normally.
Please confirm a few things.
@ROSEHAN There appears to be a RoseTube error as no videos can be played so I will hold off my testing until this is resolved to offer a complete scenario of symptoms.
Note:
~The issue persists on iPhone and iPad.
~Also, it only displays the error notice when pressing “previous track” (however, the track does play, Just the annoying notice re" expired permissions).
~Pressing “Next Track” there are no issues
If you have a problem with Rosetube, please try the method below.
If you have updated Rosetube to the latest version from RoseStore, will the same symptom appear even if you delete and reinstall Rosetube?
When pressing the back button, it has been confirmed that it occurs on iPhones and iPads.
We will fix the issue and reflect it in the next update.
To prevent the error message from appearing right now, try the following: Go to Change Device in your RoseConnect app, connect to your phone from the list of connectable devices, and then connect to your Rose device again.
@ROSEHAN This quick fix worked well. Navigation from the device using this technique worked, regardless of Previous/Next choice and for all media sources available (Integrated, Music, Qobuz, RoseTube).
