Certains possesseurs du RS130 d’octobre 2023 se sont plaint de débit Ethernet limités à 100 Mb/s.
Qu’en est il aujourd’hui ?
Est ce que le RS130 est bien équipé d’une carte réseau Ethernet à 1 Gb/s pour être conforme à ses spécifications ?
This is the Ethernet speed (SFP Fiber or SFP Copper it’s the same)For information, I have a solid network at home with competitive switches, etc.
and in WiFi :ko: :
I’m saturating the Ethernet at 1 Gbit/s (over 100 MB/s) between my PC and my NAS, and with Wi-Fi, it’s 600 Mbps with Wi-Fi 6.
Okay, the Rose’s Wi-Fi is at 5 or even less with the USB module, but still, I should at least match the pitiful Ethernet result.
And it has nothing to do with the hardware, since the Wi-Fi doesn’t use the chip that manages the Ethernet inside the Rose.
For those who have an RS130 or other (RSXXX) with a hard drive installed inside, try the test…
