I really enjoy the Rose RSA780 disc drive and the ability to rip my CD collection directly to my RS250 but after 1 week of intensive use, I thought about a few things.
- Disc recognition in the metadatabase often fails and responds to the wrong disc. Is it possible to change / select the database entry by hand to find the correct entry, when the same checksum responds to different ads / database entries?
- Is it possible to submit the hand made metadata stuff to the database so other Rose users can benefit from this work?
- The ripping protocol button after the completed ripping session is hard to read because of a wall of text. It should be much easier to recognize, if a track/album was ripped successfully or not.
My suggestion is: Instead of using words, a responding icon could do the job
a green check symbol says - ripped successful
a Red Cross says - track skipped / errors in reading track
On the position right next to the the play button, we could have a changed ripping protocol icon… if all tracks are ripped successfully we could see the same green check symbol… if there are any errors, we could see the Red Cross sign or a yellow one if some tracks are ripped correct and a few ones are skipped/with errors etc.
I know the space on the touch display is limited to show lots of status icons but a further enhancement of this visual simplification could be a green font color of track title if the correct finished ripped tracks so its easy to recognize the issues. If errors, make the font color of the meta data red.
I also would enjoy it to select tracks for ripping, to re-rip songs again if needed.
A function to rip a complete cd into 1 single file would also be a great thing.
