This happened on the first CD that I ripped. That CD was a hybrid SACD / CD of Pink Floyd: Wish you were here.
I figured that the hybrid disc was problematic. Fortunately, I had a CD only version of Pink Floyd: Wish You Were Here. So I reformatted the SSD and ripped again from the CD only version. Similar glitches, but in different parts of the songs.
I repeated this at least three more times: Reformat the SSD and rip the CD with glitches in random spots, there were no exact repetitive glitches at the same spot in the song.
I took the disc and ripped it on the CD drive on my PC and then transferred the songs off my PC to the ROSE over the network. That seemed to work fine - but counter intuitive since I bought the ROSE specifically to rip and store music directly to it. Not to fire up my home PC rip to that and then transfer songs to the rose over the network, which sort of obviates one of the reasons for buying the rose in the first place.
I have sourced another USB CD Drive (made by Pioneer) and will attempt ripping from that to determine if the LG drive is the culprit or not.
My vendor says I should have laid out another $500 for a ROSE drive after convincing me that any external USB drive would suffice.
