When I ripping somewhat old CDs, which don’t have built-in metadata, the result is a file on the SSD of my RS150 whose title is “unknown”. Okay, so far so good.
But when I rip another old CD without metadata… create another file"Unknown"…DELETING!! the previous one. That is, no matter how many (old) discs you rip, only one will appear. The RS150 rewrites the same file over and over again.
Quick fix?
1- Identify in order each unknown file: Unknown 1; unknown 2; unknown 3,… etc, etc.
2 : Allow the user to rename the file.
Any help? Thank you
Ignacio
