Which tablet is best for the Rose Connect app? iOS or Android?
Please explain your pros and cons.
thanks in advance
thanks in advance
Given the iOS app has a bug that prevent you from even register i would say Android has the upper hand at the moment at least.
I have both an ipad and android tablet. I definitely go fot the android because of the lack of the equalizer app on the iPad
Both iOS and Android are similar.
However, if you look at the APIs supported, Android has more features added.
iOS currently has more parts to fix, and I recommend using an Android tablet if you are considering one of the two.
