In the Android ROSE connect app when i select the clock display i can simply press the button several times to select the desired clock type until the selection is finished and the display returns to standard screen.
When i want to select a VU meter i have to select a type, confirm, select the next type and confirm.
Yet i think it would be much easier if the VU meter selection would work the same way as the clock selection simply by pressing through the available VU meter types without having to confirm every selection.
In the Windows Rose Connect Application the behaviour is similar.
Then king of options would be to have a button each for VU, clock on the remote control for that.
