Hello, I went to install an SSD in the bottom of my RS130 and while I was turning it over I noticed a clunking sound as if something is loose in it. Has anyone else experienced this, and if it is normal, are you able to explain what it is? I made a post in a HiFi Rose group on Facebook and a couple of people mentioned noticing a similar sound, but no one knows what it is. Seems odd for such an expensive device to have components moving around in it, but perhaps there is an obvious normal reason for it? I do have a video of the sound, but it doesn’t appear that file type is supported here. Thanks.
Yeah, same as by mine RS130.
First of all, it is normal for the RS130 to not make any sound when turned upside down and shaken.
Leads, screws, and connectors may be missing from the RS130 during transport by courier.
Please contact the distributor in the country where you purchased the RS130 and ask them to remove or fix any foreign substances floating around inside the RS130.
