Hi everyone,
I have an issue while try to output DSD 512 audio file from ROON to RS-250
It does not work.
I have a computer (installed windows 11) with Roon installed and all the music are stored in a second SSD. Music streaming via LAN is normal, but limited to DSD 256. So I tired plug in a printer USB cable from USB2.0/3.0 port from the COMP and connected to RS-250 USB IN (with USB in activated inside setting). While the USB IN is activated, I can find the USB output(Rose 250) option in the Roon setting page. I can play DSD512 files but it still downgraded to DSD256 and there is no sound from the speaker. I took a look inside the further setting of the USB DAC page in ROON, the DSD decoding only show up to DSD256.
Is a driver for the USB output for Rose is needed for DSD512 playback?
I would be grateful if someone could come up with a solution.
