Hi
I have doubts connecting my 201e to my AV amp to use as a music streamer . Which output shoukd I connect
Another question when I play music , the steamer does not play the whole album instead keep a on playing the same track
Choe
Hi
Choe
Connect to pre out to main in?
I merely using the 201E as a music streaming device . Am I not suppose to connect to the optical out to AV amp optical in .Pls advice if I am wrong
Thanks to aswiss, please note the post in mind.
Optical or RCA connection depends on which DAC you would like to use.
