Connecting a kef KASA500 EQ to RS250A streamer to power a pair of sub woofers …is it possible?
How do you connect kef KASA500 EQ to Rose RS250A to power a pair of sub woofers. Any ideas gratefully received!
@W1ll1am
RS250a has the function of preamplifier output.
It can be used by connecting the kef KASA500 EQ to the preamp output of RS250a and simultaneously connecting it to an active subwoofer in parallel.
Thanks for you reply ,
I have a Rotel RA840B Integrated amplifier https://rotel.com/sites/default/files/product/manuals/RA-840BX-OM.pdf
to power a pair of Fergusson Hill horn speakers and the KEF KASA500 to power a pair of Ferguson Hill sub woofers Shop - Ferguson Hill
Please can you send a diagram as to how to connect them to the Rose as my Rose dealer says it’s not possible to connect 2 amplifiers to the Rose as there’s only one output. I’ve tried connecting the Kef to the integrated amp and that doesn’t either .
Kind regards
David
@W1ll1am
I didn’t know you had two amps. It is not possible to use two amplifiers to output simultaneously.
I thought my answer above was that you were asking about how to connect using an amplifier and a subwoofer respectively.
