I have a DEQX Premate room and speaker Calibration processor which I can use between pre amplifier and power amplifier.
But I think there also should be a way connecting it directly to RS150B
So one of the output from RS150B goes to the DEQX Premate input and DEQX output goes back to a RS150B input and from there to the XLR balanced outputs.
Can you tell me if this is possible?
I did add picture from Premate backside with its inputs and outputs
