Hello - I have fitted a 2TB SSD to my Rose 201E, and formatted it. Using Finder on my MacBook, I can see the 201E on my network, and a folder called ‘share’. However, when I try to copy files from my MacBook to this folder, I get this message;
<<Items can’t be copied to “share” because you don’t have permission to read them.>>
Could you please clarify how I can get past this? I think the answer may be in section 3.2.9 of the manual, but I don’t find this easy to understand, nor what steps I should follow in order to be able to drag and drop files from my MacBook onto the 201E SSD.
Also - I can no longer see a separate SSD that has been connected with a USB cable - it used to be visible in the ‘folder’ view, but is no longer visible now that the SSD has been fitted, How can I see this separate SSD?
