Is it possible to route the audio of my computer audio ( especially HQPlayer) to RS130.
Connect them with a USB cable, install Rose drivers, and enjoy.
It will work without drivers (or from a Mac/Linux computer) but higher resolutions and/or native DSD would be problematic.
I am not able to find the driver for rs130. I tried Rose Connect (5.7).
That didnt work. Rose connect was not able to detect my rs130
@matbhuvi
The IP address 192.168.1.133 is IP address for your Rose device.
The IP address 192.168.1.104 is IP address for your RoseConnect PC.
To connect your Rose device and PC, only the digits after last dot should be different.
In general cases, if the numbers before the last dot are the same, we say they are in the same network.
So both your Rose device and PC has 192.161.1 which means they are in one network, so that you can connect Rose device with your PC(Rose APP). -
Is your RS130 version currently up to date? Please tell us the system version information of your RS130.
RS130–>Settings–>System info–>System version info
