Connecting RS250 to CD player via analogue inputs
We just bought a RS250 and was wondering how/if it is possible to connect our Arcam CD player to the device. The manual shows it connected via the analogue inputs, but it didn’t seem to work. Are we missing something? Are the devices not compatible?
Many thanks
Did change the source input? So hit analog input on the screen or app. Streaming part will shut down and it will use the analog feed instead
I did. When I go to the CD player app I can hear the source changing back to digital though (the internal click of the switch) and from both the CD apps it says no CDROM found.
maybe the rs250 volume is to low? turn the volume right ways to pump the volume up and make sure that the external device is configured to output through chinch outputs…
make sure to use the correct chinch connections for inputs on rs250 on the back side of the device
make sure to configure the input section to chinch inputs - not the output section
maybe you mixed up something during connection?
Hmm why do you hit CD player app?. You need to select analog out. Not the cd player app.
