Connecting Technics SL-1500C to RS520 — is it possible?
Hi all,
I’m thinking of adding a Technics SL-1500C to my setup, but before buying I want to make sure it will work correctly with the HiFi Rose RS520.
The SL-1500C has a built-in phono preamp (MM), and the RS520 has analogue inputs — so I assume it should be compatible, but I want to double-check.
Has anyone here connected this turntable to the RS520? Any tips on the best way to set it up?
Appreciate any advice!
@FM2012
Yes, the Technics SL-1500C works perfectly with the RS520.
Because the SL-1500C has a built-in MM phono preamp, you can simply connect it to the RS520’s Analog In using RCA cables.
Just set the turntable to LINE OUT, select the analog input on the RS520, and it will work without any issues.
