Connection loss in standby mode for RW800
I use the RW800 with my HiFi Rose 150B, and I am on the latest stable firmware version. When using the RW800 via a PC or phone, the connection drops while the device is in standby mode—even though it still appears to be connected—and I have to restart the unit to restore the connection. This issue does not occur while the device is actively in use.
What’s the firmware from the RW800 and how is the network configuration (lan, wifi, sharing,…)?
rw800 firmware 1.0.1(2) ethernet
No, that’s not the firmware:
Also you answered not, if the HW800 is sharing it’s network with the RS150B.
Also: What are the USB settings in the RS150B for standby (it must be always on)?
But you must not answer, if you don’t want a support…
Yes, I was looking in the wrong place on the device. I’ve just checked, and our firmware versions are the same. On the 150B, the USB status is set to 'on,' but the system doesn't shut it down. Furthermore, the RW800 is connected to the network separately via Ethernet; it does not share its internet connection.
When the RS150B enters standby mode, the RW800 also enters standby mode; however, since the network remains connected, the service should continue to work.
When you power on the RS150B from standby mode, does the RW800 appear to be properly connected as shown in the photo below?
In the end, I resolved the issue by restoring the RW800 to its factory settings. Everything is fine for now.
