Connection question
I’m planning to buy a Rose RS-150B but i like to know if you can also connect to a pre amplifier.
In all pictures i see it is connected to a power amplifier and the RS-150 is used as a pre amplifier.
But I already have a very good pre- and power amplifier so I like to connect it to the pre amplifier and (if possible) disable the Rose RS-150 volume control
Eric
You can do that. No problem.
You just set a fixed output.
You can fix the output volume from RS150.
(RS150 > In/Out Setting > Preout setting > Pre-out level setting)
