Control and automation with RTI
Good morning, I am new to this forum.
My name is Alejandro, and I am writing from Argentina.
Recently, I bought a HIFI Rose 150B and installed it in my HIFI system, which I control from an RTI application (Remote Technologies Incorporated). Now I need to control the standby and power function from the same remote control system, but I can’t find any Ethernet commands or a driver to do it.
I can’t use infrared commands because de Rose, as far as I know, doesn’t use infrared. The Rose doesn’t have a 12 volt trigger either.
Can someone give me a hand on this?
Thanks in advance
@alejandroarbo
Rose devices can only be controlled using a remote control supported by Hi-Fi Rose or the RoseConnect app.
