J’ai un HiFi Rose RS130 connecté hifi rose rd160 par un câble ubs je n’arrive pas à contrôler le volume depuis mon application. Que dois je faire?
Either RS130 or the RD16
In your RS130, in the I/O settings, there is a feature called software volume control on the output side.
Some USB DACs support UAC2 volume control, while others support HID volume control. In this case, when you adjust the volume on the Rose, the volume command is sent to the DAC to control the volume. If this feature is not supported, you can enable software volume control in the USB DAC settings in the I/O settings, and then adjust the volume via the Rose App.
