Is it possible to copy files to the SSD while RS250 is in standby? Copy my music will take … a little longer
and I am asking if the RS250 must be ON all time.
Solved. It also works in standby (always on display activated, if it plays a part).
thanks I was wondering this myself when I started the transfer and realized how long it would take. I turned the unit off and it transferred all of my files still
When using a Rose device connected to a network, the file transfer speed is slower than usual. Depending on the network environment, the average is 20mb ~ 23mb, and it comes out up to 30mb.
File transfer speed depends on your network conditions.
