Hello
When I tried to connect smsl m400 with usb output for the purpose of DAC, the Rose rs250 could not recognize the DAC. Is it possible to support smsl m400 or force usb audio output without decode ? Thank you.
Hello
Hi ryohoki,
I don’t have a smsl m400, but I have a smsl m500 and it is working well by connecting it to RS250.
I think it should be compatible with smsl m400 as well.
Would you like to connect the DAC to another USB port on the rear of the RS250?
Thank you for your sharing of your experience
I tried to plug the cable to USB storage port and it worked
May be Hifi Rose should renew the instruction
Thanks a lot
