What are these made with? I would love to make custom ones for the audio store I work for.
I’m fluent in all sorts of software development and graphic creation.
The various types of Vu-meters provided by Hi-Fi Rose are Vu-meters that we have designed and manufactured ourselves.
It is impossible to make and add to the Rose device by individuals.
Sorry
They don’t move much at all - any update to fix this
Apparently this is about 2years ago still not fixed.
Wouldn’t that depend on the music you’re listening to? With recordings that have good dynamic range, they move well. Most of the dynamically compressed stuff that is being released now, they don’t move much because it’s just constantly loud.
@BorisM
If you press the gear icon in the output settings of In/out setting, the Software Volume Control item appears.
Is this set to On? When it is off, the Vu meter works normally, but when it is on, the movement of the VU meter is slow, so our SW development team is reviewing it.
