Hi
I have abroblem that every now and than the unit (rose150b)
Will come on and write a message that the dac is not connected and i should reboot the unit…
It happens every day… ( even if the unit is standbymode)
Rafi
Does a pop-up like the picture below appear on your RS150b screen?
It seems that your RS150b is constantly having a problem with the DAC not being connected.
In that case, you need to replace the audio board of RS150b.
Contact the distributor in the country where you purchased the RS150B and request repairs.
eng.hifirose.com/Distributors
This is exactly what happens…
As I said above, contact the distributor in the country where you purchased the RS150b, explain the symptoms, and they will replace the audio board.
This symptom will disappear after replacing the audio board of your RS150b.
