Dear support,
3 days ago i’ ve played some songs with ipad Rose one connect app, during the play from another room i’ ve opened the app from my Samsung S25 Edge (as i do regularly) to lower the volume and the Rs520 switched the volume at 100% locked!!! My speakers are only 200w max and the only solution was to run finically to the amp and mute it. But the woofers smelled of burning.
Furthermore, since the last Samsung update with the security patches of March 2026, the app (latest version) stops working after a few dozen minutes from the first use (it no longer finds the RS520) and the only solution is reboot the phone. With the ipad works regularly.
This is a real, DANGEROUS problem that can cause, in my case, more than 8k euros of damage speakers + sub.
