On my RS250A I connected several external sources on Coaxial and Optical input. The RS250A seems to have trouble to detect what sample rate and bit depth is offered.
Even a standard CD played on a CD transport via optical in can’t be detected right, as the RS250A determines it as 44,1KHz 32 bits??
Several times the CD was even detected as 48Khz and because of this the CD skipped parts of the playback.
Same happens to blu-ray audio 192 kHz/ 24 bits which is displayed on the Rose as 192 kHz 32 bits and sometimes 176,4 kHz 32 bits (played back too slow)
When detection of the sample rate is wrong it helps switching back to “Analog in” and back to “coaxial”, Chances are high that the right sample rate is detected in the second attempt.
My questions:
- Can I change something in the settings of the RS250A to solve this problem?
- What does “pcm_s24_32le” mean when the Rose is playing “Optical in” or “Coaxial in”?
- Is there a possibility that the graphical screen when playing “Optical in” or “Coaxial in” will be a little pimped up? As it is now, it is a bit dull black screen compared to the colorful screen when playing streams from Spotify or Qobuz.
