Does entering developer mode void warranty?
Hi
I seemed to have entered developer mode, can’t remember how a while back. Thought it was great as had access to vu meter folder. Was going to see if I could design my own background image but now I can’t remember how to.
Still no reply to your answer.?
Nope …
I guess as long as you don’t brick your player It’s OK. If you brick it by changing crucial settings you can kiss your Rose good-bye.
I also did have this one time when I used the software remote control in the app to switch off the Vu meters.
Then the display showed te android screen with settings etc. like on a smartphone.
Didn’t manage to do it again
Think it’s a bug but don’t know how to do it again
It’s hidden for a reason. If you are not a developer better stay away.
Occasionally, developer options and Android screens may be visible due to bugs, etc.
Some options are not fully tested and can cause serious errors. Of course we will help you get back to normal, but some bugs can be difficult or take a long time to fix.
If developer options or Android screens appear, we’re sorry, but we recommend that you block access by rebooting, etc.
Thank you for response!
