Hi Rose Team,
After 1 1/2 years of joy with my Rose RS150 unfortunately I now have problems, which in my opinion started with the update to 4.5.0.5. During the XMOS update from version 3142 to version 3144, the device hangs at 100% and shows: STATE: Waiting 100% / STATE: Finding Device. This message was pending for more than 1 hour.
After a restart, the device initially played normally. The XMOS Version is shown as 3144.
But from that moment on, the device sometimes does not execute commands via the touch display quickly enough - sometimes delays from 0,5 - 1 sec. (usually this used to be done directly, almost real-time).
Since the update to 4.5.0.7, these problems have increased.
So I have performed a factory reset.
The problems seem to be even more frequent now!
The device is hardly usable anymore.
Various error messages appear, the device processes commands with a time delay of 10-20 seconds. The VU mode displays now shows frozen pointers, which during music play sometimes changed the deflection. Theme change frozen, etc.
The device often displays the following errors:
Is it possible to completely reinstall the device (I have an IT company)?
Maybe the XMOS update is not initialized correctly?
What can I do?
Thanks for your answer and help!
Thomas
