just wondering if there is a way to choose both Digital (for example USB) and Analog outputs at the same time on RS250. When I select USB output, analog output is deactivated and the other way around.
The scenario for that is: I would send the digital signal to the external DAC with the EQ (high-pass filter) and the analog signal to the subwoofer (with a low pass filter).
I’m asking, because when I had Lumin T1, this was possible. Is it a matter of SW or HW limitation?
Peter
