Digital out (toslink) - not giving signal
Dear All,
Does anyone successfully connected RS201 digital out to ANY DA converter?
I tried with Young, Accuphase 950, Luxman DA06, Benchmark, etc. but without any success. I see the lock set at 48 bits but cannot get any other signal out of it.
Please advise.
Danijel
How are you using your audio system? Is RS201 the source?
Please check things below. If no.1 doesn’t work, try no.2
  1. RS201 - IN/OUT Setting - activate OPT OUT
  2. RS201- IN/OUT Setting - OPT OUT Setting(the gear image) - OPTICAL Output Setting -try lower sampling frequency
Thank you,
I will, albeit all DACs I tried are working properly with high sampling frequency.
