Digital volume control
I just Boght your rs150. I need a digital volume control. Do you know when this option will be added?
Niccolò
Digital volume control means that you want the gain of the digital output of RS150 to be adjusted?
Yes.
Thanks, like the analogic. Using the remote control.
