What is the digital out (coax) volume control? 32bit?
Does the sound degrade as you lower the volume (i.e. losing bits)?
Marty
Marty
Basically, for OPT OUT/ AES/EBU, and COAX OUT, the maximum possible transmission rate is 24Bit/192KHz.
If you use internal DAC of Rose, you can use full specification of Rose streamers, 32bit 768kHz for RS150B.
Lowering the volume won’t degrade bits.
Thanks for the clarification. I’m trying a DAC (less) approach with a Peachtree GaN1. Digital coax straight into the amp.
I don’t know if this is an ideal config using the 150. Hate to bypass the ESS…
