Hi
Please consider adding D.I radio
It contains many different Types of music like synthwave , trance ,deep  house, and ambient etc
I believe it’s hugely used - it’s probably like tidal but more geared towards dance .
Many thanks
    Hi
Many thanks
You can add them yourself if you pay for a premium DI.fm account. I’m sure that DI.fm shut down all free streams a while back due to changed royalty laws. Hence why they are not on tunein any more.
Hi
I’m using free version on iPhone , how do I add it to the rose rs250 please.
Many thanks
I can airplay it , but wanted to know if I could add it to rose itself .
The free streams are only available on their app.
If you want to add di.fm streams to your rs250 you will need to pay for Premium access on DI.fm.
Then you will be able to add them,
example :-
https://listen.di.fm/premium_high/techno.pls?listen_key=123456789abcd (once you have premium access you will have your own personal key)
There is NO way to add free DI.fm streams…
Thanks for speedy response- appreciated.
