Direct connection to TV
Can I connect my new RS150 directly to my TV utilizing the standard HDMI (not ARC’s) on both for video and Optical for audio?
@Newby
The RS150 has two HDMI ports.
If you connect the HDMI OUT port on the RS150 to the HDMI IN port on your TV, you will be able to view videos played on the RS150 on your TV screen.
For more details, please refer to the video below:
You can also connect your amplifier to the RS150 using an optical (TOSLINK) cable for audio output.
