Is it possible to disable an input when not in use? Would be nice to be able to this, changing input with remote will be easyer
Currently it is impossible to disable all functions of the input. One must be selected.
Input/Output settings are also possible to select with the remote control.
Follow the instructions below with the remote control. Please let me know if it does not work.
Rose device–>Settings–>Audio Settings–>In/Out Settings
Agree with @sober . Inputs and outputs should be autodetect. When there is nothing connected then it is quite useless to show up as selectable options.
Its much easier for user and very logical.
