Hi @ROSELOA ,
this is a new situation for me. I noticed that most of my outputs were grey (so not white or gold), except for HDMI (gold, so was selected for an unknown reason) and USB out (white). I had internet radio on and it played through my loudspeakers, until I tried to select the digital outputs or the analogue outputs, then it stopped (which is normal behavior, I think, that the source is stopped when you try to select another type of outputs).
When I click on a grey output, the circle becomes visible while the sound stops, and I hear a light click in my loudspeakers, but then the circle disappears and nothing visually happens.
I have reset the device and took out the plug for some minutes, but nothing changes.
Earlier the digital outputs were white and the analogue outputs gold.
So I guess this is a bug?
Regards,
Dominiek
