Please see the attached screenshot here.
In order to manage a big quantity of my song database I usually put a Set of Album into the same album name. That makes the set of Album showing only one icon on the screen instead of dozens or even 100 icons for a set of album. It works perfectly for my other app such as Audirvana or Poweramp for Android. But as you see in the screenshot it does not work in RoseConnect.
Another screenshot shows you even worse case, a set of Album with 153 CD I need to have 153 icons for that Album?? That’s weird…
Is there anyway to solve the issue?
I believe A LOT OF people have the same headache for this issue.
