Display brightness
I wish there is an shortcut for display brightness. As we know, unfortunately, HiFi Rose 250A does not have automatically adjustable display brightness. It is odd because every phone or tablet has that. But, anyway, I have to dig into menus every day when in day/night change. Also, setting for brightness could be more logharitmic as i use setting 3 for day and setting 1 for night. So, just two numbers between and impossible to fine tune for everyday use.
So, instead of going into menus every time, there could be a shortcut like for a clock.
@Burle
Currently the feature you are talking about is not supported
I aware of that. It is a suggestion for future software upgrade. Please, make shortcut for screen brightnes. You can make a choice to optionaly use volume knob for that. Volume knob is anyway useless whe you connect it digitally. It is awful that you go deep in the menu for changing screen brightnes
@Burle
I will forward your request to our software team.
They plan to review the content and add it after reviewing whether it is possible or necessary to add it.
