Display different art from files within same folder?
Hi, I’m noticing files with different art within the same folder are all showing the same image on the display upon playback. It is; however showing the different art via the iPhone app. Can there be a fix for this possibly?
@JOHNxxEIRE
You said that when files containing different art within the same folder are played, they all show the same image on the display. Does this symptom occur when using MAC RoseConnect?
I don’t know as I don’t own a computer. Files are transferred from Synology to internal SSD via cloudsync WebDAV, if they’re in the same album folder they’ll show the same cover of one of them.
Maybe it’s due to the same album title metadata; I can’t find a way to leave album metadata field blank as a file always gets autofilled with the title of the folder it’s in. I use a Samsung phone to edit the metadata, the Autotagger app. I tried a few apps they all do it
