Hello, would it be possible to add the option to adjust the font size for each line in the display settings?
Thank you for your valuable suggestion.
Currently, it is not possible to adjust the font size for each line in the display settings.
There have been similar requests in the past, but it seems difficult to implement font size adjustment.
You can try it not because it is easy, but because it is difficult.
