Display view RS250
How to pick album cover or weather view with the app?
First of all, please check if your music files are scanned.
(RS250 β†’ Settings β†’ SystemSetting β†’ MediaLibrary β†’ Check if your storage is scanned)
After Step 1 is done, check here…
RoseConnectPremium APP β†’ Setting β†’ MediaLibrary β†’ Re-Download database
You should be able to see album covers if everything is done right.
However, there is a problem that the album cover is not visible due to a current bug.
We will fix the issue in an upcoming update.
We apologize for any inconvenience.
I can pick only home view, clock or VU mode.
