When ripping CD’s the Display typically shows Track 1 and Track 2, which allows you to see the ripping progress of each track. When Track 3 and 4 start ripping the display still shows Track 1 and Track 2. Is there any way the screen could scroll so it’s always showing the active track being ripped? If you want to see the currently active track, you have to manually scroll the Display.
Hello, I understand what you mean.
However, at the moment it doesn’t work as you said.
