Hello, do RS201E have USB output? For example, output to an USB DAC.
Yes, you can transport your digital data with USB port on rear panel. It is called just USB, not “audio out”. In “in/out settings” you have to validate USB output, and with gear circle choose your USB DAC, and confirm. Then, you can use your RS201 as digital trasport/streamer.
Blue, faster one.
I hope you would have no problem.
Get it, thanks a lot!
May I ask one more question, if I play Tidal by USB output, does it mean RS201E will transport ALL data to my DAC without any processing?
Also, can I transport the data of CD to my DAC via USB?
When USB DAC is connected, the external DAC will do all works about DAC.
Also, you can transport the data of CD to your DAC via USB.
