Does not play below 96khz
My Rose 250 stopped playing tracks that are below 96khz. How do I fix this?
Are you using built in DAC and analog output or one of the digital outputs? If you use digital outputs which is master clock, Rose or DAC? Do you use upsampling function? For me it looks like you are using manual sample rate setting on the DAC.
