Hi
I’m thinking of plug a Blu-ray external drive to my RS250 via USB, does RS250 support Blu-ray rom that I can play blu-ray disc??
Thanks,
Mananab
Hi
Thanks,
Mananab
Some roms with good compatibility may work with RS250, but it’s only for usual CD.
However direct DVD/Blue-Ray play is impossible with RS250.
If you want to play Blue-Ray with ROSE, you need to do ripping with PC and play the video file.
