Dolby Atmos via airplay
The following setup: I play a song from Todal in Dolby Atmos via my iPhone via airplay to the RS 250A. I listen through headphones! Does the Dolby Atmos signal reach the headphones or is it overwritten in the DAC? Thank you very much!
@karlphilippmoritz
We do not support Dolby Atmos. Support is not available even through AirPlay
Airplay2 supports Dolby Atmos, but even if you play Dolby Atmos music, the Rose device does not support Dolby Atmos, so it plays lossless.
OK thank you. I was hoping that the signal would at least be passed on to the headphones, since the Dolby Amtos signal is generated in the iPhone and not in the DAC. Greetings
