With large playlists it can happen that you accidentally copy the same songs into the list twice. I would appreciate it if you could add a parameter like allow duplicate songs yes/no. Thank you
The feature you requested seems difficult to support in the DB we are using.
If the feature that displays a message in duplicate sound sources is supported in the future, we will support that feature as well.
